发表于2023-08-03 22:29:12回复0浏览 1239
It is powered by a custom-built turbocharged and intercooled 2.0-liter 4-cylinder boxer engine that meets the requirements of its class, including a mandated 33mm restrictor and 22psi boost limit. To spec, the engine produces 320hp and 380 lb-ft. of torque, while a SADEV six-speed close-ratio transmission sends the power to all four wheels(译文:这个动力源自足其组别要求的定涡轮压器和中冷的2.0升4气缸水平对置发动机的车,包括制33毫米节气门限制和22psi涡增压极限。为了符合规则,发动机可以产生320hp马力和380lb-ft矩,SADEV六密齿比传动统将力传递给四车轮。)那么问题来了【家猜猜是什么发动机】
