发表于2023-04-20 12:49:26查看 152回复0浏览 152
关于丰田Tacoma和Hilux的区别,这个说法简单直接。 “The Tacoma is specifically built by Toyota to accommodate a trailer, while the Hilux is better suited for hauling more weight. As for towing capacity, the Tacoma is rated at 6,800 pounds, while the Hilux is rated at 6,172 pounds. The Hilux, on the other hand, can tow up to 2,240 pounds, while the Tacoma can only tow up to 1,685 pounds.” 但是应该后面load而是tow。 也就说,Tacoma会拖,合带拖车(主要是国人房车)。Hilux会装货,能一吨货,比者多250公斤左右。 这说明Tacoma自重大,相对应来说耗也肯定大,但是空载的时候舒感可会比较好,假如后挂是样的话。
