这款由梅赛德斯-奔驰和AMG联合推出的新型超级跑车有着无与伦比的技术组合:铝制空间框架车身,鸥翼式车门,AMG 6.3升V8前中置发动机,最大输出功率为420千瓦/ 571马力,扭矩为650牛米,采用7离合变速,铝叉梁运架。
AMG SLS从0加速到100公里/小时只需3.8秒,可以达到317公里/小时的最高速度(电子限制)。每百公里13.2升的油耗(合计)使它在竞争领域处于领先地位。
The new super sports car from Mercedes-Benz and AMG makes for an alluring proposition with its unrivalled technology package: aluminium spaceframe body with gullwing doors, AMG 6.3-litre V8 front-mid engine developing 420 kW / 571 hp peak output, 650 Nm of torque and dry sump lubrication, seven-speed dual-clutch transmission in a transaxle configuration, sports suspension with aluminium ble wishbones.
The 'Gullwing' accelerates from 0 to 100 km/h in 3.8 seconds, before going on to a top speed of 317 km/h (electronically limited). The fuel consumption of 13.2 litres per 100 kilometres (combined) puts it at the front of the competitive field .
